メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2686回答 すべてを表示
Phone shuts down when taking selfie with flash
So I have a customer come in asking if I have heard about this issue before.
she has changed screen from a competitor and when she takes a selfie using the flash the phone turns off and you have to hold lock + homebutton to get it to turn on again, has anyone heard of this problem and is it a bad screen or is something else broken?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
4 件のコメント
this happened to me. and now it wont turn on at all. sooo
さんによる
I have the same problem. It started awhile ago but I didn't do anything about it. It has gotten a lot worse. At this point sometimes doesn't turn on for a few days.
さんによる
so i was on snapchat and i tried taking a picture with the front flash and it just completely shuts off my phone. back works perfectly fine but the front just doesn’t work. it will work very rarely. anyone know what’s wrong with this?
さんによる
I was on snapchat and took a front facing flash photo and my phone flickered and turned off. My phone wont even reconize the charger anymore, We took it to a repair store and we got a battery and screen replacment. The phone still would not turn on. I have jailbroken my phone but is was working fine. I also did have water damage like 1 month prior but we already got that fixed. If anyone knows a solution that would be great.
さんによる
コメントを追加
3件の回答
最も参考になった回答
It's the battery. When it can't provide the high amount of power output from flash the phone will auto reboot itself.
You may see that while plugged into charger or near fully charged it does not occur.
You'll need to get the battery replaced to fix this problem.
iPhone 6sのバッテリーの交換
iPhone 6s Battery
iPhone 6s Batteryの画像
製品
iPhone 6s Battery
$29.99
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
So I had this problem tonight I tried taking a picture on Snapchat with my front camera and flash and it shut off and my phone as I am writing this is at 88% and this happened no less than about 5 minutes ago and also my back camera doesn’t work at all and there is a diss connected wire in my phone. Is any of this related? iPhone SE
さんによる
Sometimes the rear camera can get disconnected from a prior repair.
This occurs because the metal cover may not have been put back on to keep the connectors in place for the screen and cameras. So after a few drops the rear camera might disconnect itself usually reseating the camera fixes the problem.
For the shut down problem that is most likely going to be the battery you may see this may not happen while plugged into a charger.
さんによる
コメントを追加
I would try another screen as some repair centres buy fully assembled screens and just swap home button I.D.
It might be a defect cheap part on the screen instead of them swapping the genuine parts over to the new screen
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thats what I though too, she was going to find the receipt and complain to them.. but she will be back to me in a couple of weeks for a battery repair
さんによる
I'd try that first and see if it resolves the problem if not there will be other options to try.
さんによる
コメントを追加
either or all:
  1. check the battery - settings app -> battery — under battery health -> Peak performance capability - it should say that battery is supporting normal peak performance. If not — a battery needs replacement.
  2. some short inside or water damage and thus corrosion or some in-between so that if power usage exceeds the base levels - the battery does not cope and / or short occures and the system shuts down.
  3. loose connector
The phone may need to be opened to evaluate 2. and 3.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
nicolay.94 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 10
今までの合計 4,493
