That's not working,still won't crank over.
What next?.... That's not working,still won't crank over... Please I've tried new battery...it's a system problem, I think it's a keys,phobs, problem.....? HELP !!!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Christine are you sure its a security issue have you had the codes read . If it is a security issue I have had success in two different ways first being to disconnect the battery for a day with the headlights one to remove any residual power from the computer . this reset the computer and the security system will also reset and make sure you use a factory OEM key . If this brings no joy a new battery can also help. if the battery is week it often causes the system to activate hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 155
1件のコメント
Christine - first you have the wrong name to work well with autos. Maybe @jimfixer knows more about this.
mayer さんによる
