System doesn't turn on after SHUTDOWN. Only works on RESTART
Hi All,
I spilled some tea on my MacBook's keyboard but cleaned it immediately and nothing seemed to be an issue. I used it for a few hours after this and when I SHUTDOWN my system and tried to turn it on again, it did not turn on.
So after a couple of days, I opened the casing and unplugged the battery and plugged in again after 2 mintues. Then, I connected it to the MagSafe charger and turned on my Mac it worked!
It even works when the MagSafe charger is not connected and it works on the battery only mode. However, the problem re-appears when I SHUTDOWN my MacBook.
So, everytime I SHUTDOWN my mac, I have to open the case, unplug the battery and replug the battery, then plug in the charger and press start and it works. Mac works if I RESTART my mac, but doesn't turn on if I SHUTDOWN mac.
I have looked at plenty of videos and forums, but haven't found an answer for this and would appreciate your help with this.
MacBook Info
- MacBook Pro (Retina, 13-inch, Late 2013)
- Battery according to Coconut Battery -
- Battery Status - Good
- Battery Failure - None
- Keyboard - No visible issues. All keys work just fine.
Mac doesn't turn on after SHUTDOWN only
この質問は役に立ちましたか?
