メインコンテンツにスキップ
モデル番号A1312 / Mid 2010 / 3.2 GHz Core i3もしくは2.8 & 3.6 GHz Core i5もしくは2.93 GHz Core i7, ID iMac11,3
382回答 すべてを表示
How do I create a bootable drive
Hello iFixit Community,
I have an iMac that is running El Capitan and it has official bit the dust. How do I create a bootable drive so I can bring it up enough to get my photos off of it? Does it matter what OS I download onto the external hard drive? Or Can I say boot it up with HighSierra?
thanks in advance
-H
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Do you have a new system? If you do and your system is still able to power up you might be able to get the system into Target Disk Mode Use target disk mode to share files between two Mac computers
If not don't fear you still could take the drive out and then using either a 3.5" hard drive case or a Universal Drive Adapter will allow you access from the second system. Here's how to take it out: iMac Intel 27" EMC 2390 Hard Drive Replacement
But before you go down this path have you tried running diagnostics to see whats wrong with the system? Locate the grey CD/DVD disks that came with your system use it to boot up your system.
Universal Drive Adapterの画像
製品
$24.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
HermioneCumberbatch さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 67
