メインコンテンツにスキップ
2014年9月19日に発売されたこの4.7インチ画面のiPhoneは、iPhone 6 Plusの小型バージョンモデルです。モデル番号はA1549、A1586、A1589で識別できます。
5058回答 すべてを表示
Bad - no celluar coverage
Okay so have this iPhone 6 with little till absolutely none celluar.. I have looked into it, there is not any physical damage to either wifi/gps antenna, or celluar antenna that i can see, nor on the connections, but i went ahead and ordered the new wifi antenna and celluar antenna.
but is there a way i could check if the IC chips are bad or something?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
Try Dialing *#06#, do you get your IMEI? Also, look in settings and see if your IMEI is listed there and also Modem Version. there are a few IC chips on the logic board that can lose connection, have bad traces (Pads) or just be in need of replacing.
Knowing if *#06# brings up IMEI and if IMEI and Modem are listed in settings can help know if you are experiencing a chip problem, software issue or just a antenna issue.
The Charging port has your "Data" antenna and your upper antenna is for your Wifi/Bluetooth/GPS
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Be sure you have all the updates installed for the system and do a factory reset just to check that it isn't a software issue. If it isn't software related, possibly the parts that deals with the cellular side has gone bad. The wires is a good idea to see if they haven't gone but they aren't usually the common reason. Still worth a shot.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Petter Berget さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 71
