Why is my phone showing the battery like it's charging then it's not
Why is my phone showing the battery like it's charging but not ALSO why is it that when I enter bootloader it freezes when I click one single choice PLZZ HELP
It can depend on a couple things,
The charger you have may be incorrect. The charger should display the amps on it, and also inside the battery, make sure they match up.
Another thing is your battery may be fried, could be best to get another one, Try charging your phone while it's off too.
I used to be using the incorrect charger and I was using my phone plugged in and my battery was still discharging.
I'm not sure what you mean about bootloader, you may have to go more into depth...
Hope this helped :)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 53
@pccheese can you give the PC software that gives the status on this phones battery?
mayer さんによる
@mayer I don't know of a PC solution but I have a nice app available on the play store.
https://play.google.com/store/apps/detai...
George A. さんによる
