Can I purchase just the "Home button"
Everything works fine on my iPod Touch except the home button which is not working at all. Can this part be purchased? Is it easy to install?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
if you're just talking about the plastic button itself, I have seen just the home button part listed for sale at welovemacs.com
look up your model iPod touch, and then look in the Service Parts section
but if there's something else wrong with the switch itself, you may need to investigate the problem further, it may be a problem on the internal board.
このアンサーは役に立ちましたか?
Well yes you can, but if you were to replace the NAND chips you need a lot more expereince then you would if you just get a 3rd party SSD with the size you want.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,066
