Appleの iPhone 5sは2013年9月10日に発表されました。このデバイスの修理は全モデルの修理と類似しています。そしてスクリュードライバー、こじ開けツールが必要です。GSM か CDMA、16か32、64GBがあり、色はシルバー、ゴールド、スプレーグレイが選べます。
3946の回答 すべてを表示
iPhone 5s completely dead board troubleshooting
Hi,
I've got a customer's iPhone 5 that is completely dead. I got 0A on power supply (connected on battery connector) whit power button pressed and released.
I tried hard reset, DFU mode, replace the battery, replace the screen and power on only the board. However the phone doesn't respond to anything. I take off the shields and checked the board, but it looks ok, no corrosion points, no components smoked.
I would like help to start the board analysis. what is the better points to check in this situation? What is the lines and the values that I need to check?
Thanks
Felipe
UPDATE: I just put the phone to charge and after some minutes the all phone warmed up.
コメント:
New Update: I put a new battery and new charging port and plugged on wall charger.
After a few seconds the coil L16 got hot and after more 1 or 2 seconds the coil L18 too.
by
remove and replace both, theres possibly a problem with the pmic as i had similar problems on a 5s
by
Add a comment
Android 修理キット
交換用スクリーンやバッテリーの修理キット
ショップを見る
Android 修理キット
ショップを見る
1 件の回答
Chosen Solution
When dealing with a “dead” phone, you have to start at the beginning and check PP_BATT_VCC, PP_VCC_MAIN and PP5V0_USB. I would start by checking to see if those rails are shorted to ground. If one of these rails is shorted to ground, then you will need to identify what is causing the short. It could be a bad decoupling capacitor, conductive debris or defective IC that is directly supplied by those rails.
If they are not shorted, then you can connect, preferably, a known-good battery (or a current limited DC power supply with the appropriate connector adapter) to see what voltage you measure. If the voltage is low or lower than the battery voltage (which you measured before plugging it in ;>), then there could be a short circuit on secondary subsystem that is causing the battery or DCPS to be current-limited.
Then you move onto the PMIC and check the voltage rails it generates:
  • The PMIC generates a lot of voltage rails. They are all important (for obvious reasons) but the ones to check first are as follows: PP_CPU, PP_GPU, PP1V8_SDRAM, PP1V2_SDRAM, PP_VAR_SOC, PP0V95_FIXED_SOC, PP3V0_Tristar, PP3V0_NAND, PP1V8_ALWAYS and PP1V0.
  • The PMIC also generates, what I would consider secondary, yet still important voltage rails for the following sub-systems: PP3V0_MESA, PP1V8_VA_L19_L67, PP3V0_PROX_ALS, PP3V0_PROX_IRLED, PP3V0_IMU, PP3V3_USB
Note: The net names change slightly from one iPhone model to another
Start probing and report back.
Score 1
コメント:
Hi
The board is: 820-3292-A
I connected the board in a power supply configured whit 3.8v and limited to 150mA.
All tested points the power supply keep these parameters: 3.8V / 0.088A ~ 0.092A and I got the measurements only plugging the power supply, I not pressed the power button
by
PP_VCC_MAIN (C270) = no shorted / 3.78V
PP_BATT_VCC (C387) = no shorted / 3.78V
PP5V0_USB_CONN (TP57) = no shorted / 0.0V
PP5V0_USB_PORT (C272) = no shorted / 0.0V
PP1V8_SDRAM (C293) = 0.010 ohms / 0.0V
PP1V2_SDRAM (C308) = 0.420 ohms / 0.0V
PP3V0_NAND (C182) = 1.089 ohms / 0.0V
PP1V0 (C442) = 0.980 ohms / 0.0v
PP1V8_VA_L19_L67 (C104) = 1.100 ohms / 0.0V
PP3V0_PROX_ALS (FL45) = 1.094 ohms / 0.0v
PP3V0_PROX_IRLED (C44) = 1.093 / 0.0V
PP3V0_IMU (C347) = 1.137 ohms / 0.0V
PP3V3_USB (C35) = 1.143 ohms / 0.0V
PP1V8_ALWAYS = I cant find a "test point" to get the parameters
I not fount any reference about these nets
PP_CPU
PP_GPU
PP_VAR_SOC
PP0V95_FIXED_SOC
PP3V0_Tristar
PP3V0_MESA
So, all the PP points are 0, so can I assume that PCMI is "burned"?
by
Maybe, but limiting the input power to 150mA is probably not enough.
by
Add a comment
Add your answer
Felipe Kashiwagura will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 1,515
