Upgrading RAM on A1278 MacBook Pro to RAM 1666 Mhz
Hello
I upgraded EFI my macbook pro 13 2.4 Ghz / Can i use memory with 1666 Mhz or 1867?
この質問は役に立ちましたか?
Hello
この質問は役に立ちましたか?
The minimum required RAM: 1066 MHz PC3-8500 DDR3 SDRAM.
Yes, you can use faster RAM up to a point! I would only go up to 1666 MHz as the slower 1066 MHz is getting hard to find. You also can't exceed 16 GB between the two slots.
You're wasting your money going with 1867 or higher as the systems memory bus can't leverage it. In fact it may be too fast for the slower read/write of this system (RAS & CAS).
このアンサーは役に立ちましたか?
You mean go up to 1600 MHz . I cant find ram with 1666MHz
Can i use RAM with 1600 MHz?
Look here: Your Apple MacBook Pro (13-inch, Mid 2010) that works! No need to go higher.
If i can use faster memory, why not?
OK lets look at like a car... My car takes regular petrol (gas) do I gain anything using premium fuel? Nope! The engine doesn't care it runs the same way with either. MacBook Pro's are similar they are expecting a given value and thats that. Putting something in thats faster won't help it. As much as people will try to tell you otherwise there is no noticeable benefit! Don't take my word watch this: RAM Speed and Timings As Fast As Possible
it is logical. thnks
過去 24時間: 3
過去 7 日: 7
過去 30 日: 20
今までの合計 3,691
1件のコメント
Your systems specs: MacBook Pro 13" 2.66 GHz Core 2 Duo (Mid-2010)
Dan さんによる
