メインコンテンツにスキップ
修理作業が必要なデバイスに対して使用する電子装置の使用方法を紹介します。
78回答 すべてを表示
Cnc controller will not send voltage to stepper motors .
I have a tb6600 4axis controller that isn’t working . I bought off of ebay and wired everything up and I get no movement from stepper motors . I’m looking for someone to repair the board or at least test it for me . I need any help at this point I have checked all the components on the board and can’t find the problem .
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Hi,
just joined and saw your question unanswered.
I find it is a careful process configuring your application to suit your router.
1. Can you verify your cnc application is correctly configured ?
Use a breadboard / breakout board with a male and female db25 on each end.
Pins define -
LPT pins Pin symbols Functions
1 PWM 0-10V output control
2 STEPX X axis pulse
3 DIRX X axis direction
4 STEPY Y axis pulse
5 DIRY Y axis direction
6 STEPZ Z axis pulse
7 DIRZ Z axis direction
8 STEPC C axis pulse
9 DIRA C axis direction
10 LIMIT-1 LPT input signal 1
11 LIMIT-2 LPT input signal 2
12 LIMIT-3 LPT input signal 3
13 LIMIT-4 LPT input signal 4
14 ENABLE_ALL All axis enable input
15 LIMIT-5 LPT input signal 5
16 NO USE
17 RELAY Relay control
18-25 GND Common GND for PC
Test with a logic probe (test light) or meter
using your controller program EMC2, etc
reset all axis
is pin 14 enable-all true?
step each axis in each direction and see if signals are correct at the breakout board
DIR and STEP
toggle each limit switch and test signals
Next check the signals at the motor connectors
(do not disconnect motors while power is on)
I gave up on parallel/serial port controllers and now use a usb controller running GRBL using separate micro stepping drivers, open source, runs on Arduino, much better.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Josh Tucker さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 574
