Why doesn't my ignition key unlock the drivers door on a 2002 LS430?
Ignition key unlocks all doors but the drivers door, You must lock and unlock the drivers door by inserting the key into the drivers door to lock or unlock just the drivers door.
この質問は役に立ちましたか?
6 件のコメント
Does your Lexus have the door closer as well (Easy-Close Option)?
oldturkey03 さんによる
@oldturkey03 I didn't realize this was a system in these cars, this might be why it's so expensive from some retailers then!
Jasen Friedle さんによる
@vehiclefreak409 I guess it's a build-in butler..... definitely snazzy!
oldturkey03 さんによる
@oldturkey03 I guess so! But it also introduces the issue of complexity and cost when it breaks xD
Jasen Friedle さんによる
@vehiclefreak409 absolutely! You should see the way it is setup. Cam positioners, sensors, multiple motors and all. Okay, I get it! I pass and use valet service for my 2002 Ford F-150 with 250K miles ;-)
oldturkey03 さんによる
1以上のコメントを表示
