メインコンテンツにスキップ
2014年9月19日に発売されたこの4.7インチ画面のiPhoneは、iPhone 6 Plusの小型バージョンモデルです。モデル番号はA1549、A1586、A1589で識別できます。
5198回答 すべてを表示
iPhone 6 Charging Problem After Water damage
Hi @refectio !
Recently i repaired totally dead water damage iPhone 6. Phone boot and work fine. After 2 weeks start problems with charging.
First, phone wont charge, when i connected wallcharger, but via computer charge without problems. Now phone definitely stop charge. So i do:
Replace U1700 Tristar
Replace U1401 Tigris
Do hard jumper Q1701
Check all Tristar and Tigris caps for short - all is ok
Replace Dock connector
Replace Bettery
After measurement voltages i found FIRST problem, when i have connected battery and dock charging port to the motherboard Tigris E1 pin with name CHG_ACT_DIO is low - 0V. When i connect this line to 5V, phone still won´t work.
After measurement working board this line have 5V.
After cleaning board with ultrasonic cleaner phone start charge for only 3-5mins. After then, phone stop charging and do not want charge anymore. ,I must put board again to the ultrasonic cleaner and clean, board start charge for 3-5mins and after this time stop charging. To this problem is board fully working (i can power on board)
Tigris and Tristar i replaced 2-3x i used new one and one from working boar also. Same result.
Did you seen it before?
PS: I clean with ultrasonic cleaner only area below SIM card connector, i do not clean the entire bord. I do not believe that there is short.
Thanks for your question
Best regards, Tomáš
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Hi Tomáš. I would always clean the entire board. Just because you can't see any water or corrosion, that doesn't mean that no water came in contact. It may also be under the IC's, particularly the PMIC, CPU, NAND, Touch IC's etc. So it's always important to do a full cleaning procedure.
CHG_ACT_DIO will go low (0V) when it detects something in the charge port. When that happens, VCC_MAIN & BATT_VCC are connected together via Q1403 and battery charging occurs. The phone will work regardless of the logic level of CHG_ACT_DIO.
Is the phone working properly except for the charging issue (to this problem is board fully working (i can power on board))?
このアンサーは役に立ちましたか?
スコア 2
コメント:
phone is working but do not want still charge after
Replace Bettery
What next i need to check?
さんによる
You need to check the PMIC and it's output voltages, specifically the ones for Tristar and Tigris. You may also have incorrectly installed Tristar or Tigris or perhaps some of the pads underneath them were slightly damaged.
さんによる
what happens if I make short ( jumping ) in Q1403 , will battery explode
さんによる
コメントを追加
回答を追加する
Tomas さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,119
