No check valve on water pump
In the Kenmore HE3 front load washer,I noticed that there is no check valve after the drain water pump. Would a check valve after the pump benefit the washer - keep more dirty water out? Prevent wash from smelling?
I don't see where a check valve would hurt. Here's a forum on smelly wash, I liked a couple of the ideas, especially on adding some water: http://forums.macrumors.com/showthread.p...
このアンサーは役に立ちましたか?
+1 not a dirty job either ;-)
There is a Check Valve / FLAPPER on the pump Outlet... It Is A 1" Round, Flat Piece Of Rubber That Works Like The FLAPPER In Your Toilet... If you do not see this Flapper on your pump, it has washed down the drain... It is only held on by a Rubber Band like piece on the flapper itself...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,798
