Laptop ons but no display
How do I change my Display chip or fix it ... do I need to replace the whole board
@miquart2005 connect an external display first. If that shows appropriate then it is not your chipset. Check your LCD in that case. If it does not show properly (and you have not done anything else like a BIOS update etc.) it is possible that your GPU has failed. You would have to replace the motherboard unless you know how to reball BGA chips.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 125
