メインコンテンツにスキップ
Replacing "rubber cup" of a key on MacBook Pro 2016
So I got a double click problem and had to replace the "rubber part", which is under the hinge:
https://www.replacementlaptopkeys.com/pr...
It seems like it won't hold in place anymore so the key does not work properly. Should it be glued? Did anybody tried to replace it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
2 件のコメント
@mayer just went to upvote your answer and it said it was deleted :(
さんによる
I deleted it, it belonged to another question
さんによる
コメントを追加
1 件の回答
最も参考になった回答
So I had to glue it for it to hold, but the butterfly part which I ordered was from 2017 model (mine is 2016) so the key was lower and didn't work properly in the corners. But it solved my double click problem and I been happy with it for a while.
Later I got same double click on another key and had to replace my keyboard under the warranty. I got new 2017 keyboard model and new battery as a nice bonus. 2017 model is much better so I would highly recommend anybody with such issue to replace the whole keyboard.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
What kind of glue did you use?
さんによる
Regular super glue. Key worked but the replacement was from 2017 model and it didn't fit properly on my 2016 so it was a bit lower than others. After a while I got double click problem on ANOTHER key so I went for a replacement keyboard under a warranty. Got 2017 model – no problems so far.
さんによる
i got the same problem on my "D" and "L" keys, so i contacted to Apple for support but they said that isn't their problem (&&^& them) so could you explain me how did you glue it? or well what kind of glue did you use ?
さんによる
コメントを追加
回答を追加する
Dmitry Sadovnychyi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 2,840
