2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1461の回答 すべてを表示
Touch ID not working after replacing home button cable
Hi, I recently replaced my home button cable after accidentally ripping the home button cable while replacing my phone's screen, I bought this part https://www.amazon.com/dp/B00XNA80Z6?ref... After successfully installing it, I found the the home button works too go home and things like that. However the touch ID does not work. Any suggestions?
Thanks
Add a comment
Android 修理キット
交換用スクリーンやバッテリーの修理キット
ショップを見る
Android 修理キット
ショップを見る
1 件の回答
Most Helpful Answer
Unfortunately, only the original home button will work for TouchID. The home button and logic board are paired, so you'd have to replace both if you want TouchID functionality. Here's another discussion about it in case you're curious: Any possibility to replace Homebutton AND have Touch ID still working?.
Score 2
コメント:
UPDATE: I just found this article that shows a glimpse of hope on the horizon (pun intended): https://ios.gadgethacks.com/news/after-e...
by
Oh I had thought since it was just the cable or would be fine
by
Add a comment
Add your answer
Monica Alexander will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 108
All Time: 2,919
