Tv won’t stay on
Tv turns on but turns back off
この質問は役に立ちましたか?
Take the back off and see if you can spot any domed or leaking electrolytic capacitors - probably the commonest problem (See https://therestartproject.org/wiki/Basic...).
If they all look fine check for anything else that looks overheated or burned.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 862
1件のコメント
bbeaup828 does this happen immediately? What have you checked? Can you turn it back on as soon as it turns off or do you have to wait to turn it on? Remove the back and take a good look at all the boards. Check for any damage. Post some images of your boards with your question so that we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that
oldturkey03 さんによる
