want charge or power on
Plug phone in charge don't show charg
er light and want charge or anything no water damage screens not cracked or anything
u need a new micro usb charging port.
このアンサーは役に立ちましたか?
U22 shows only charging ,but wont turned on.
Try a different charging cable if that doesn't work clean the charging port and have a look for any bent pins on the port. It could be the battery has died or charging port dirty or faulty. Get a battery try that if that doesn't work you will need a new charging port
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 705
