メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
271回答 すべてを表示
How to have SSD and HDD with a 2x2,5" bracket in iMac MA199LL/early 06
Hi everybody!
My name is Jim. I want to upgrade my old MA199LL/ 17" early 2006 Imac. I can swap the old hdd with the ssd i bought but, do you think it's possible to add a bracket for two 2,5" drives? I would prefer to keep both the SSD and the HDD inside the computer. As much as i searched online, it is possible to fit the bracket though, the height will reach the limit of the given space. But what about the connections? I saw only one SATA port on the board. How can i connect them both? I even searched for a caddy to change the optical drive with it but, to no avail. I'm waiting for the new screen to arrive - it will take some time to find it's way from the U.S. to Greece - and i hope i'll be able to solve this by then so that, i won't have to open the case again.
Any help would be much appreciated!!!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
さんによる
Thank you for your reply but my model is MA199LL. https://everymac.com/systems/apple/imac/.... Double checked it with my s/n. Thanks anyway!!!
さんによる
コメントを追加
1 件の回答
選択されたソリューション
Be careful here! You want to watch how much you spend on these older systems.
Going with a SSD drive I think is pushing it. While I understand your desire to get the best performance from your system it has limitations! The biggest one is the last version Mac OS-X (10.7.5 Lion) you can run on this system does not offer TRIM services so using a SSD will be iffy unless you can find an old copy of TRIM Enabler
The second is this systems HD SATA port is only SATA I (1.5 Gb/s) so you'll need to find a drive that supports this older slower interface. Most SSD only offer SATA II/SATA III support (auto SATA speed sensing).
As to add a second drive sorry your system only offers one SATA port so one drive is your limit. You would need to replace your PATA optical drive to a PATA to SATA caddy to hold a second drive. Keep in mind the PATA interface is very slow! So you would only want to put a HD which holds the data files.
But thats getting overly complex and expensive!
Frankly, I would go with a SSHD like Seagate FireCuda SSHD this drive offers support for SATA I and has a SSD cache onboard so you don't need to worry about TRIM services at the OS level as the hardware takes care of it all. For reference here's the drives spec sheet: FireCude Specs. Review your SSD's spec sheet it needs to state it supports SATA I. You'll see this drive does! SATA Transfer Rates Supported (Gb/s) - 6.0/3.0/1.5
You'll get the zip you're looking for and yet have the depth of a traditional drive. And you don't need to give up your optical drive!
Here's the IFIXIT guide you'll need to follow: iMac Intel 17" Hard Drive Replacement
このアンサーは役に立ちましたか?
スコア 2
コメント:
First of all thank you for your reply!! I have already have a white 2006 MBP - brother in law provided - with a crucial ssd in it along with a caddy in which he installed the factory hdd. It's running 10.7.5 and i must say, given the restrictions it's decent. I used this MBP to format a Samsung 850 pro which is compatible to the specs you've already stated - sata 1.5. I also have a copy of TRIM enabler running on MBP. About the PATA optical drive, to be honest i never bothered to check what protocol/connection it uses. Since i'll be using the factory hdd as my data drive, it doesn't mean much how i'll connect it. To be honest, i'm not keen either to remove the optical drive so i'll take your advice and buy an external usb 3.0 case - because i may use it later with different drive and usb port - for the hdd. So, to sum up, since there's only one sata port, i'll just put inside the ssd and use the old hdd with a usb case. Thank you again for your time, effort and speed!!!
さんによる
コメントを追加
回答を追加する
Dimitrios Pantazidis さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 92
