メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1778,1784。 GSM かCDMAの32、128、256GBがあり、色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラックがあり。
1364回答 すべてを表示
Why are there colorful lines on my screen?
I accidentally slammed my phone on a wood table because I was mad at my parents (bratty Ik) and now when my screen is dark there are colorful (greenish) lines going up and down my screen.. any tips? I have already tried hitting the back again and resetting it... and I can’t go to an Apple store because the nearest one is 2 hours away
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
There're different colors lines going down my screen. Then I put my fingerprint in or pin its become white a the screen. Its click anything that i didn't press. So i just want to know how much do I have to pay to get it fix.
さんによる
コメントを追加
3件の回答
最も参考になった回答
Well Alison, this might be because the pressure of the slam could have affected the layers inside of the phone. One of the layers consists of the things that keep the screen glowing. you could have permanently broken the phone. But don’t worry. The 2 hour drive to the apple store is worth it because they know how to fix it. So do I. I’m not sure if I could tell you because I don’t want you risking permanently destroying your phone..
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Alison Gates considering what happened to the phone and that you now have "colorful (greenish) lines going up and down my screen" leads me to believe that you have broken display assembly. There is no fixing it, only a replacing. Here is the guide for it iPhone 7 Plus スクリーンの交換 and the part is available at places like this iPhone 7 Plus Screen
To verify that it is the display, post some pictures of what your screen shows with your question. That way we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that.
iPhone 7 Plus Screenの画像
製品
$74.99
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
iPhone 7 Plus スクリーンの画像
ガイド
難易度:
中レベル
30 minutes - 1 hour
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I’ve had the same problem. the cause of the slam is either anger issues over a game, you have a very bad tantrum, or getting mad because a friend is better at your favorite game. the slam can be so hard the screen malfunctions and breaks you privilege to tap anything on the screen.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alison さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 23,862
