メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1050回答 すべてを表示
App calls on speaker, mic doesn't work
Hello everyone,
I just got my phone back after being repaired, updated ios 11 and I have a problem. During app calls whenever I set it on speaker, the other side can't hear me anymore. Just like if I pressed the mute button instead of the speaker. Normal phone calls have no such problems. Is there anyone, who could help me please? Thanks, Katka
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
What was the repair for - replacing the display assembly or replacing the charge port? If you had the display assembly repaired then the microphone on the front camera/proximity sensor flex assembly may have been damaged. Does the front camera and proximity sensor work okay? Or, if you had the charge port assembly replaced then perhaps the microphone on that flex assembly was damaged.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@ittechrepair Yes, they have exchanged the display assembly. But the thing is, that when I call without using any app, then it's no problem using speaker, the mic works.. My front camera and proximity sensor work fine. I also talked about it with my friend and she said she's had the same problem for already 6 months and it appeared out of nowhere.
さんによる
コメントを追加
回答を追加する
Katka Hájíčková さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 21
今までの合計 310
