I lost my dash lights 0n my Ranger?
My dash lights are all out except 3 lock/battery/air bags what is the cause
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If are you referring the the engine light and mil, brake light and abs lights this requires a new dash cluster this is a common problem with late 90s and early 2000s year fords . The only fix is a new instrumentation cluster . Try to get one from an aftermarket source as new ones from ford are not much better than the old one. This is one of the only things I tell customer to never buy from the dealer. I've replaced many in ford focuses and rangers . You can pick one up from Rockauto.com . Hope this helps
このアンサーは役に立ちましたか?
What exactly is an instrumentation cluster are you talking about the actual Dash bored
This is a 2007 Ranger
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 968
1件のコメント
@ramtuf what exact years is this and what have you checked?
oldturkey03 さんによる
