My network led not blinking
I have serious problem with my laptop
First the network icon is red X and said Not Connected
The network/ Lan led is not blinking,.
Fn F8 which use for turn on/off lan is missing
Is my lan card broken or what? I try for download driver but not solve the problem, now I'm really frustating
この質問は役に立ちましたか?
5 件のコメント
What OS version are you using?
DrGlowire さんによる
@richie01 has it worked for you before?
oldturkey03 さんによる
Hi,
Have you checked in Device Manager to see the state of the LAN adapter? What does it show, working OK, disabled, problem etc?
If disabled have you tried to enable it in Device Manager? (right click on entry and select enable).
If you cannot enable it in Device manager,check in BIOS and see if there is an entry in there to disable/enable the LAN.
jayeff さんによる
I check in device manager and it show nothing, try install driver but show message the adapter is not found, i using win 7
Richie さんによる
And its enable on bios btw
Richie さんによる
