メインコンテンツにスキップ
Samsung smartphone released in January 2016. Model SM-J320
48回答 すべてを表示
Phone touch screen not responding Samsung J3 [J320n]
after doing a hard reset the touch screen is still unresponsive. also when it was dropped initially about 10 hours ago the left side of the screen had a tiny crack. any ideas on what could be broken? Screen or motherboard?
any help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Jack Nicolsen you cannot make the determination without working on it. The number one give away on here is this "dropped initially about 10 hours ago" and " the left side of the screen had a tiny crack" You have a failed digitizer. Replacing that will resolve your issue. This video should help you with that. Don't start soldering on the board until you have properly checked everything else.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I just cleaned the digitizer port contacts with contact cleaner and it worked.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jack Nicolsen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 7,878
