メインコンテンツにスキップ
Lenovo社によって製造されたラップトップモデルの修理ならびにサポートガイド。
2546回答 すべてを表示
Lenovo G460 laptop is not charging when turned on
HI,
Lenovo G460 laptop (battery Smiley Happy) is not charging when turned on. When laptop turned on and plugged in , then intially it charges for a minute to five minutes and then it stops. When we mouse hoverd on the battery icon is displaying message as the percentage of battery available. No message as "Charging" is displayed. But it charges when turned off. Once after tutning off the laptop it charges from min to 100 percent without any issue. thank you.
Can someone suggest me the solution.
thnks
Indra reddy
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Hi @jayeff , Thanks for the response.
Battery doesn't discharge quickly. full charging does stays for around 90 minutes.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi @indrareddy ,
Do you have Win 7 (32-bit) installed?
If so, you could try uninstalling the Lenovo Energy Management software, recharging the battery to 100% and then reinstalling the "latest" available energy management software suitable for your laptop from Lenovo.
If this doesn't work you may either have a faulty battery or power adapter.
Hopefully this is of some help
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Indra reddy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,977
