メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
Screen turns on by itself - dock connector?
I got a broken iPhone from eBay, when I put it back together it worked ok, but a ribbon cable on the dock connector assembly was broken. The microphone etc. did not work.
I bought a "new" dock assembly on eBay, but since putting everything back together again the screen lights up and displays the unlock slider about every 20 seconds. It does not do this when playing music, or when plugged into the computer.
Having googled it looks like it might be a faulty dock connector - does anyone know whether or not this is the case? I also replaced the headphone assembly and vibration motor, but I installed these yesterday before the dock connector.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
I've established that is is the dock connector. A message briefly flashes up now about an incompatible accessory, and when I use the old dock connector it works fine.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Well done on fixing your problem- pretty strange! Thanks for posting your solution, learned something new which is always good. Please change your comment to a solution, then accept it as an answer so others can see your solution worked!
さんによる
コメントを追加
Mmm.. It can't be the Dock connector, it must to be a slack screw, make sure the board is fastened by all the screws, if its not, wash it it isophropylical alcohol, but its definitively not the dock conector. :D
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
What is isophropylical alcohol????really bad predictive text?? LOL :-)
think you might have got this one wrong ichris.... Louisanilsen fixed her own problem . And it WAS the dock. Learn something new everyday...
さんによる
コメントを追加
回答を追加する
louisanilsen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,685
