メインコンテンツにスキップ
The 2003-2005 Pontiac Sunfire is a more streamlined updated version of the popular car.
7回答 すべてを表示
Why is there gas spraying into the tube that leads to my air filter?
There is a small black hose that leads to the tube my air filter is in & the other end is on a cyndrilical metal like item...something to do with fuel I'm guessing. Gasoline comes out the end that goes into the tube that leads to my air filter, my car popped & started smoking the other day after I tried to start it, I took the air filter out, the small black hose off & plugged it up...help! What is the metal cylinder shaped item that the other end of the hose i's hooked up to called?
Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
@bsrigamarowe post some good pictures of what you are looking at with your question. That will allow us to see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that.
What exact year is it and hat engine size does it have?
さんによる
コメントを追加
1 件の回答
ベストアンサー
The only line that should be attached to the air intake is the pcv exhaust . Are you sure this has gas coming out or is it oil . you may need to replace the pcv valve if your getting excessive blow by. The cylindrical item is the PCV valve . Hope this helps
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
It is definitely gas, my air filter was covered in it which is probablying why it popped & was smoldering when I tried to start my car. When I had the hose attached it was my car had a difficult time starting, I had to pump on the gas pedal & when I'd let up it'd start. Now that it's disconnected it starts just fine.
さんによる
@bsrigamarowe could you post some photos of the part your talking about
さんによる
コメントを追加
回答を追加する
Bernard さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 2,388
