メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Inspiron 15-3521は、オプションのタッチスクリーン機能と15.6インチディスプレイを備えています。このノートパソコンは、マット仕上げの筐体にテンキー付きキーボードを搭載しています。
Why my lappy won't boot up?
On pressing the power button, the power LED turns on but there's no reaction from the laptop, the system doesn't turn on. Also, while trying to power it off, even holding the power button doesn't make the power LED off, we have to remove the battery and then only the power LED is gone. Please help me.... Please find a way for me to fix it. Thanks for your valuable time.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@rajwadkar07 remove your power adapter, your battery and your RAM. Then hold down the power button for something like 30sec. After that reinstall the power supply only. See if it powers up. Errors like this can be caused by bad memory modules, bad power supplies as well as bad batteries. Of course you can never rule out the power button or motherboard. Check the AC adapter first. Make sure that it provides proper voltages to your computer. Here is an online service manual that will help you to work on your computer.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Didn't fixed it bro.
さんによる
So you checked your AC adapter? What voltage did you get?
さんによる
I didn't check it, a professional did, they said RAM, Hard drive and charger was working fine.
さんによる
@rajwadkar07 I am confused. you have a professional check those parts but not the computer? If they checked all the parts and you still do not have a working computer, exchange the motherboard after you check the CMOS battery, unles the professionals already checked that as well.
さんによる
コメントを追加
I would do all that old turkey said, but also while your in there, I would say disconnect your bios battery as well. Usually with a laptop they are encased in black plastic and plugged into the motherboard. I would take that out, then plug only your power button back into the motherboard, then hold it down. That will drain the CMOS and reset the bios to the factory settings. I would also suggest replacing the bios battery if you can because a completely dead battery could cause issues too. Best of luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Raj Wadkar さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 23
今までの合計 706
