メインコンテンツにスキップ
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
120回答 すべてを表示
Solder Pads tracks have come off Galaxy 3 during repair any way to fix
Hi Gentleman
I have been repairing for quite some time but my solder skills are average
During removal of a charger port two solders pads came off
Not sure why maybe too much heat
I have researched it but it is very confusing and conflicting
What is the easiest way to replace the missing tracks/pads as they are very small but need to fix them otherwise board is rubbish
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@tabletrepairsoz there is really no easy fix for this. you will have to post some images of your damaged board as well as the damage itself. That way we can see what you see. iFixitでの質問に画像を追加する方法
Sometimes the pad can be rebuild, other times you will have to apply jumpers to the closest component after the solder pads. If you are unsure about your abilities to solder I recommend that you send the board to someone who specializes in microsoldering.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Edward Ghanime さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 52
