Why wont my screen stay off
My screen should go off after being idle for 1 minute, but when it goes off, it just comes straight back on again, So my battery is always running down.
Anyone have any idea's on this?
Thanks, Cliff
この質問は役に立ちましたか?
Thanks, Cliff
この質問は役に立ちましたか?
This thread describes many potential culprits.
Check your settings under "display" and make sure it's set to the time you want it to be.
Another cause might be that an app could be wakelocking your phone so the screen stays on. There's an app for that. (To detect it, that is).
Also if you have Pandora installed, look in the Pandora settings and make sure it's set to conserve battery. The Wakelock app (linked above) would probably detect it, but I figure Pandora's common enough that it's worth mentioning directly here just in case.
Good luck!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 67
