メインコンテンツにスキップ
Released Apr 2008. 7MP camera with 3X Optical Zoom.
22回答 すべてを表示
No power after trying two new batteries.
What else could cause the camera not to turn on?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
@walk biggest issue with this type of camera is the door to the battery compartment. If it does not seat properly or does not make proper contact, your camera will not get power. If that looks ok you will have to go ahead and disassemble your camera for further testing. Here are the guides to work on your camera. Follow the block diagram and measure the voltages as shown on it.
Your camera has three fuses and the one to check is F1 on the power board.
Let us know what you find.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Hi @walk, before that, is there any problems or issues from this camera,
you mentioned you had used new batteries, you tested and does the battery feel hot / warm when remove ?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
where can i take my camera to have it checked ou either in Silverdale or Lynwood WA?
さんによる
コメントを追加
回答を追加する
Cheryl Walker さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 50
今までの合計 1,685
