The Logitech UE Boom 2 is a waterproof, portable Bluetooth speaker known for its 360 degree sound. The Boom 2 comes in a multitude of vibrant colors and patterns.
36の回答 すべてを表示
US Boom 2 speaker broke after being in water
Completely made sure all of the ports with sealed shut and proceeded to use my speaker for the first time in water. DID NOT COMPLETELY SUBMERGE IT, it was probably in about 1 in of water for 10 minutes when the speaker shut off.
It will not work anymore.
Was advertised to be water proof for up to a half-hour in about 1 meter of water?
コメント:
There are some limits here! It's not really intended to be used as an underwater speaker only survive a dunk turned off. {https://www.gizmodo.com.au/2015/09/ue-bo...|UE Boom 2 - The Best Bluetooth Speaker Is Now Waterproof For The Same Price]
by
Dan , unfortunately I do have the UE BOOM 2, which is the water resistant one. Advertised to be able to work in 1 meter submerged for 30 min.
by
Hi Nicole, the same happened to my it boom 2. It was submerged partly for barely 2 minutes and it hasn't turned on since. Did Logitech help you out?
by
Add a comment
Android 修理キット
交換用スクリーンやバッテリーの修理キット
ショップを見る
Android 修理キット
ショップを見る
4件の回答
Most Helpful Answer
Water probably go into the Headphone/DC port. Since they did advertised as water resistant, I would contact Logitech to see if they can do anything about a replacement.
Score 2
コメント:
That won't work. They'll only help if it came defective or DOA, but if you caused it, then they don't care.
by
Add a comment
Make some story up.... I got mine replaced same thing happened with me
Add a comment
Why won’t my UE MEGABOOM speaker work after it had been submerged under chlorine water ? It makes a deep tone and shuts off .
Add a comment
I have a wonderboom and i researched to double check if it was water proof and it said yes and so I had put it in the water and now it is temperamental with turning off or on and is stuck on sound down so when I turn the sound up it automatically turns it down again
Add a comment
Add your answer
Nicole will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 111
All Time: 4,836
