My charging port on my vapourizer has been ripped out by the cable...
My Aspire Zelos kit has had its charging ripped out by the charging cable... Is there any way of restoring it?
if you can access where the charging port is meant to contact with the rest of the vaporizer then with a bit of soldering (and a little research on how to solder) you should be able to, i would also recommend you looking at the cleaning guide to give a general idea on how to take it apart
このアンサーは役に立ちましたか?
I am looking for the usb port for the soldering but I can't find the replacement piece, any suggestion?
このアンサーは役に立ちましたか?
Assuming it’s a micro USB port, you should look for something like this:
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 20
今までの合計 6,827
