has my moltherboard failed?
When I turn on the computer, the keyboard starts blinking about every 2 or 3 seconds. The screen never lights up. I can turn it off by holding on/off button for 15 or so seconds. But every time I turn it on same thing happens.
この質問は役に立ちましたか?
5 件のコメント
Hi @tyng98 ,
Can you hear the fan running?
If so, try connecting an external monitor to the HDMI port to see if there is any display present at all after you turn on the laptop and hopefully Windows has loaded.
If there is a display on the external monitor, try holding a torch at an angle close to the IdeaPad's LCDscreen to check if you can detect an image there.
jayeff さんによる
Mine does the same thing and you can't hear the fan spin up when you try to turn it on. It doesn't even post, can't even get to the bios.
Lachlan Wiebe さんによる
Hi Lachlan Weibe,
Are there any indications evident when you connect and switch on the charger and then if there are does anything happen when you try to turn the IdeaPad on?
jayeff さんによる
You see this thread?
https://forums.lenovo.com/t5/Lenovo-Yoga...
Anthony さんによる
I took mine to a local repair shop and their diagnosis was that the memory was bad. Since its soldered to the motherboard, I would need a replacement board to potentially fix it.
The parts and labor was more than the laptop is worth but I'm thinking about buying the motherboard and trying my hand at replacing it.
Amazon has them for about $300.
Jason Moe さんによる
