メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
unknown "Screw" from my iPhone 4
Hello,
I want to change my iPhone from black in white. Now i have a "screw". I do not know from where this is.
Here are two pictures. Where i have to install this thing? Sorry for my English.
http://i152.photobucket.com/albums/s199/...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
It dosent look like a Pentalobe, are any of the screws missing on the bottom of your phone?
さんによる
コメントを追加
8件の回答
ベストアンサー
What you need is iFixit's iPhone 4 liberation kit to remove the pentalobe screws from the bottom and to install phillips screws you can remove with any old screwdriver.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Hey Doug here....That is a nut that goes in between the motherboard and the back of the screen. Its a little hard to explain but there is a cover plate that takes 5 screws next to the camera and covers the connectors...it goes under the lowest screw....under it and the screw goes right thru it.... hope this helps
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
doug 2k is correct.. i just installed a color lcd assembly swap and that same lil bugger came off my logic board. the location of this piece is hard to explain but doug did a pretty good job.. look on the logic board, to the right of the rear camera connection, there is a little metal piece of the EMI cover that looks like a Y but rounded, that little piece that fell off went under there..
i'm not exactly sure if the piece is mandatory but my phone is functioning without it..
if you look at step 13 here, (iPhone 4 のロジックボードの交換) your "screw" insert would belong beneath where the yellow circle is..
i dunno how one would repair this part... mayyybe using some krazy glue gel (?) ---> which i wouldnt recommend because that would be apparent to a tech if you ever chose to warranty the device.
sorry so wordy..
-mike :)
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
here's a pic of what I was talking about..
[image|97604|size=thumbnail]
さんによる
but on a second/third/fourth look at your pics, the part may be from the dock connector cover, its located along the same side of the logic board as the one i pictured here. right next to the battery tab..
さんによる
コメントを追加
This looks like something that a screw goes in to. I wouldn't worry to much if you are missing a screw, but this is what holds in the screw, and might prevent it from being shorted out. Make sure that all your screws are tight, and if one isn't that is where this goes.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This looks like two washers. I had one left over from my disassembly of an iPhone 4. Take a look at your logic board and see if there is any gap between the metal covers and the PCB - I suspect that the washers are belong there.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
theres a few of these in the iphone 4. in my opinion (only caus i know im now missing this bit cause it fell out and i could get it back in) is that up top just under the horizontal display cable there is a screw that is supposed to go in there. in between the metal chip cover and the motherboard there is suppose to be one of those, thats the one thats gone on me, but if i were you i wouldnt worry about it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes. This collar is under the yellow circle screw from that link above. Mine popped out though the phone seems to work without it, it is disturbing not to have in there. All instructions for logicboard removal should warn the person on this as it pops out. It is so tiny that trying to reposition it (better caution could have been taken) it shot out somewhere in my kitchen. I may make a small collar out of aluminum since I am concerned this MAY minor-ly may effect the grounding. If you are like me it is quite disturbing to have something not go back in a disassembly the way it was or missing. Just about NO information about this is available AND the collar or insert is not in any IPhone 4 screw kits I have seen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Looks more like a screw anchor.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Antiker さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 5,820
