Why doesn't my phone turn on
I have tried turning it on using factory mode and charging it and turning it on safe mode but nothing happens. I'll take the battery out and then put it back in and try to turn it on but all I get is a glitch and nothing happens. I have dropped a couple of time and dropped it in a little water but that was a year ago. Right before this happened I didn't do anything to it, I didn't drop it at all.
この質問は役に立ちましたか?
5 件のコメント
Is the battery swollen at all?
Jimfixer さんによる
Eva Mercer what is that "all I get is a glitch"?
oldturkey03 さんによる
The battery is not swollen at all.
The glitch is it does this thing where it turns on for one second but all I see is a white line going through the top. It only does this when I take the battery out then put it back in.
Eva Mercer さんによる
If you hold the power button and the volume down button at the same time do you get the restore menu?
Jimfixer さんによる
Eva Mercer you identifies your phone as a J16. Could it be a J1 (2016)?
oldturkey03 さんによる
