Repair guides for Android cell phones manufactured by ALCATEL.
877の回答 すべて表示
No sound for incoming calls or texts
I have an Alcatel One Touch. It's been working fine until yesterday afternoon. In the morning, I was still getting sound notifications for texts and phone calls. In the afternoon, I realized I had missed calls and texts because no sound came with the ringing of the phone or the incoming text. Actually, the phone goes straight to voice mail, after first saying the voice mail box had not been set up (which it had, but I did it again). So I have checked that the volume is up, and that the ring/sound tones are set as they once were. I re-set up the voice mail box and it is working but the phone goes directly to it without ringing. I have restarted/rebooted it, and I have shut it off, waited, and turned it back on. I'm not sure what else to check. I have had others more savvy than I am look at it and they see that all is set up correctly but it isn't making sounds with incoming calls or texts.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメント:
Hi @cherthejoy ,
Have you checked the following settings in "phone app", to see if the Call Barring - Incoming Calls - All calls barred option is unchecked or in Call Forwarding that the options are set correctly?
による
How do I get back the sound of my phone.... I have a cousin she borrow my phone and download some app after a while.i used my phone and does t have any sound it only have a sound when I call someone. I hear them but it doesn't have a sound in incoming call and messages even in man applications like youtube, Facebook and other apps that I used..... Can you help me to fix it
による
Hi @ maria Colly Villaflor,
Try starting the phone in safe mode and check if the sounds now work OK.
If they do then a downloaded app is the cause of the problem.
You need to uninstall each downloaded app, one by one, and test the phone between each uninstall to see if it is now OK. Once the phone works correctly, the last downloaded app that you uninstalled is the culprit.
による
when a text is sent to me I have no sou nd so I miss the taxes how do I get it back
による
It doesn't ring but I end up with a voicemail . So I call my tablet with my other phone it rings 3 times on my calling end then into voicemail no ring.
による
表示する 1 他のコメントを
コメントを追加
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
当社のショップを閲覧する
2回答
最も参考になった回答
@cherthejoy go to Settings --> Applications --> Phone
There should be a section there called "Notifications".
Make sure that that is switched on.
Also do this with Settings --> Applications --> <whatever messaging program you use>
この回答は役に立ちましたか?
スコア 2
コメント:
Hi @avanteguarde ,
Just curious, how does this equate with i/c calls going straight to voicemail? (see OP quote "Actually, the phone goes straight to voice mail")
による
OP also said "no sound came with the ringing of the phone ".
による
Which would be right if i/c calls went straight to voicemail, bypassing the phone.
How would one know otherwise if there was an i'c call/message besides tone signal or vibrate alert.
For instance, does the screen light up and indicate a call when tone/vibrate signals are muted or off?
による
Well, i/c calls wouldn't "ring" if they were not getting to the phone. It would literally go straight to voicemail without ringing. If you hear "ringing" then the call goes through. Second indication is OP stated that the phone is getting texts with no sound. From the statement that the phone had "had missed calls and texts " also indicates the phone is ringing with no sound.
による
If all the suggested settings are correct (presumably the loudspeaker is working OK), would a corrupted phone app cause this? Perhaps clearing the phone app cache perhaps?
OP stated that she only rebooted the phone not reset it.
による
表示する 2 他のコメントを
コメントを追加
Actually u need to change the APN setting, instead of LTE to E only.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Cherrie さん、ありがとうございました!
統計データを表示:
過去 24時間: 54
過去 7 日: 370
過去 30 日: 1,480
今までの合計 27,426
