メインコンテンツにスキップ
Could I put a 2007 logic board in this?
Hey guys,
So my 2006 MacBook Pro has a logic board problem which causes red everywhere that there is black which is super annoying but it goes away when I plug it into a external monitor.
But that’s not the question, so anyway, I was wondering if I could put a 2007 Core 2 Duo logic board into it to replacing the existing Core Duo logic board?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Are you sure you want to put the money into a system which has known GPU issues. You will likely need to swap out other parts as well as Apple altered the display and keyboard subsystems.
This is a money pit I would recommend looking at getting a newer Unibody system (new or used) ideally a i5/i7 model.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks for the input I will most likely get an slightly newer windows laptop as all I was using this for was gaming with windows xp but didn’t want to spend to much extra money if I didn’t have to also is there any way to fix the red lines on black???
さんによる
Sorry no aces up my sleeve here, you need a new GPU chip (new logic board).
さんによる
コメントを追加
回答を追加する
Noah salinas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 48
