メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1169回答 すべてを表示
Don't know if screen broken or something else...
Hello,
I dropped my iphone 3s once and no more images appears in the screen.
Some time later I put it to charge and screen light went on, but it shows only some kind of pixel pattern in grey, with vertical white tin lines.
At this stage I cannot tell what is wrong. Screen seems not cracked, since backlight went on but nothing seems physically broken.
The only thing I can do is to press both buttons at the same time and screen goes black like it turn off. When I turn it on again, I get some weird horizontal lines showing on and off for some seconds, then some color randomly placed lines and then a nice white screen for some seconds before the weird horizontal lines dance begins again, like and old tv with a bad antenna.
I will like to have an opinion in this, in order to know what can I do with it since I hate to trow away stuff that can be fixed.
I took off the screen a little bit and the connector #1, and the screen goes black and you must 'turn on' the phone again. that connector is a little devil, who will umplug itself very easily. But with the connector right on place the problem is the one described.
The others connectors, I didn't remove. They seem well placed.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
coursparis this "some kind of pixel pattern in grey, with vertical white tin lines" is pretty indicative of a broken display. Here are the guides iPhone 3G needed for the repair. To find a replacement display will not be easy or cheap.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
with grey I don't mean lcd liquid, just a degree of very light grey in a perfect pattern. Sometimes is not exactly grey but light blue...
さんによる
coursparis add an image of what your screen displays with your question. Use this guide iFixitでの質問に画像を追加する方法 for that. It will allow us to see what you see.
さんによる
done! thanks!
さんによる
I would advise you to repair phone in a workshop or find the skilled person on this website
さんによる
コメントを追加
Nobody? please......
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
coursparis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 17
今までの合計 191
