メインコンテンツにスキップ
2014年9月に発売されたSony Xperia Z3 Compactの修理ガイドです。
82回答 すべてを表示
Antenna Board REplacement for D5803
Dear Comunity,
I am having the exact same issues described in No Service at all thread for the regular z3. The suggested solution is to replace the antenna board.
I cannot, however, find said article for my version of the phone and am a bit lost as to what I can do. The two phones probably do not have the same hardware, right?! Do you think it would be a possible solution to try and only exchange the antenna cable? This one can be found for the d5803.
Thanks,
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@alb3rt you are right, there isn't one. You can try to replace the cable first. Sony does no longer have any schematics available for their phones. Here is the recommendations according to the service manual for No or bad network. Use these guides Sony Xperia Z3 Compact Repair to work on your phone.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
@oldturkey03 ok, thanks for the helpful comment. I'll try replacing the cable first then. might come back here with further questions though.
cheers
さんによる
コメントを追加
回答を追加する
albert einstein さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,208
