メインコンテンツにスキップ
2015年3月に発表され、同年4月に発売されたGalaxy S6はGalaxyラインの中で最高のデバイスです。端にカーブが施されたスクリーンはGalaxy S6 Edgeです。
487回答 すべてを表示
Phone goes to safe mode after camera replacement!
So while trying to replace the back camera on my phone I ripped a small metal under the camera. Now my phone goes directly in safe mode, and volume buttons don't work. I need a solution to make the volume work again with jumpers
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hey Betim, that looks like it could be some electrical bridge and without it attache it is causing the phone to fault into safe mode. I believe the only options to get the phone working again is to have that reattached or the whole board replaced.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
With jumpers? You have severed a Ribbon, there is no way you are going to be able to jumper a ribbon cable break, what you need to do after a ribbon cable is damaged is locate the part and buy one that is not damaged and then replace it. if the ribbon comes attached to something with no release you will need to bu what ever it is factory mounted to. if both ends have a release you can just replace the cable.
The problem is easier for you than some one that has a internal cable separation since the break is obvious.
check this out and see if it the one you need, if it is Not then locate the one you do need. this one costs 2.60 USD how cheap is that?
http://www.ebay.com/itm/Volume-Button-Fl...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Betim Aliji さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 71
