メインコンテンツにスキップ
Repair guides and support for televisions manufactured by Sony.
748回答 すべてを表示
Power light blinks 5 times on SXRD™ Rear Projection TV KDS-55A2020
My 55-inch SXRD Rear Projection TV powered off all of a sudden. When I try to turn it on now, the power light blinks green as though it is warming up but then it shuts off and the power light blinks 5 times repeatedly. Someone has suggested that this may be the light ballast but I would like to be able to confirm this before spending $100. Also, I cannot find this part in new condition so any hints there would also be helpful!
Thanks!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Michael Lauritzen blinks 5 times is indicative of a faulty lamp driver is faulty. The symptoms of this are no picture or sound. Before replacing the ballast, replace the lamp.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
I have the same 5 red blinks with no picture or sound. I've replaced the lamp and still have the same problem. Do you have any other suggestions?
さんによる
Same thing here replaced the bulb same 5 blinks any thoughts ??
さんによる
carmen doucette if you replaced the bulb but still have the 5-blink then it is likely a faulty lamp driver. You may have to replace the ballast.
さんによる
コメントを追加
回答を追加する
Michael Lauritzen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 1,310
