Top case corner dented, can I remove and fix it
My yoga was knocked out of my hand and when landed the corner of the top case was dented. Can I replace it myself?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @calebj77 ,
Here is a link to the service manual for your laptop.
Not quite sure what you mean by "top case".
If you mean the cover behind the LCD panel, scroll to p.87 in the manual to find the part number for the LCD cover appropriate to your particular variant. Then "Google" search using the part number only to find suppliers of the part. The manual describes the pre-requisite steps that are needed and then the procedure on how to access the part, by removing the LCD panel (p.61).
If you mean the upper case (where the keyboard is) then you'll find the part numbers on p.79
Hopefully this is of some help.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 1,168
1件のコメント
could you post some photos
iFixitでの質問に画像を追加する方法
has the damage caused the laptop to lose any functionality . any screen damage?
Jimfixer さんによる
