メインコンテンツにスキップ
Joy-Conは、Nintendo Switchゲームコンソール用のコントローラーです。
107回答 すべてを表示
Replaced joy-con shell; bungled joystick?
I did a shell replacement on my whole Switch, including the body and both joy-cons. Everything went great except for the right joy-con: I must have screwed up the joystick because now it’s permanently sending “joystick right” anytime it’s connected to my unit. The joystick itself looks just fine, it doesn’t look bent. The only thing I can think of is maybe I screwed up the ribbon cable when I plugged it back into the joy-con circuit board.
Has this happened to anybody else? If so, is there a fix? If not, is there a place I can buy a new joystick assembly for the right joy-con?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
最も参考になった回答
I have a similar issue - try lifting the rubber flap that covers the Joystick guts (just under the stick). Then blast some compressed air into here and move stick blast, move stick, blast. See if that helps. Then run the analogue stick configuration from settings.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
How did you get the rubber cap back on? It won't fit in for me.
さんによる
You list it back with two pins it will flap and stay back if done right. A little fiddly but if not you hold while someone else sprays
さんによる
コメントを追加
回答を追加する
Ben Kreeger さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 2,404
