メインコンテンツにスキップ
Apple Watch Series 2は2016年9月7日に発表され、同年9月16日に発売されました。
132回答 すべてを表示
Would replacing my screen jeopardise the watch’s waterproof properties
I have a large, deep scratch in the screen of my Apple Watch series 2. It has started to get on my nerves, and I have begun to consider replacing the screen myself. Would replacing the screen cause the watch to no longer be waterproof?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
First it is water resistant not waterproof
https://support.apple.com/en-us/HT205000
If you do the repair, any remaining warranty you have will be kaput.
Replacing it yourself and getting as good a seal as the factory did is unlikely.
The part is out of stock and expensive. I'd call Apple as see what they are charging first.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
There's no way to guarantee that it would still have the same water resistant rating. Also, the replacement adhesive strips I have found so far are a bit thicker than the OEM one. So after you re-set the screen in place, it sticks up a teeny, tiny bit higher than it did originally. Literally, we're talking a fraction of a millimeter, but it is enough to feel. And if you really look closely, you can see the difference too. Does that matter? Maybe, maybe not, but personally, I worry a little bit about the edges of the screens being that much easier to chip.
Personally, before I did anything else, I would try picking up a good screen protector (probably one of the plastic ones like the stuff from Armorsuit, not a tempered glass one) and see if that covers up the scratch enough to not bother you so much.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Luke Rogers さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,204
