Stand mixer drive unit is loose
drive unit bounces loosely on mount
この質問は役に立ちましたか?
Patrick Thurston I am a bit confused by your question. It is not entirely clear to me where your mixer is loose. It might help if you post some pictures of what is going on with your mixer, with your question. Use this guide for that. Check this videoabout more information on the drive gears etc. The image will show you how it is all put together and may help you further out. If the unit is loose on the stand you do want to check that the column (6) is properly attached to the base (7) should be 3 screws. Same with the gearcase (5) mounted to the column (6) with 5 screws. Tighten those if loose.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 241
