メインコンテンツにスキップ
MacBookファミリーは2006年5月に登場しました。Appleの人気ラップトップであったiBookから引き継がれました。
4227回答 すべてを表示
Diagnosis loose connection or bad logic board?
My Mac seemed to have had a bad hard drive. It does have a weak battery, but will hold a charge for 10-15minutes. When turned on it would display a folder with a question mark. I replaced hard drive.. worked a few days then started displaying same folder.
A week ago I disassembled and reassembled removing and reinstalling hard drive as well as disconnecting and reconnecting other connections. It worked like a charm until I let the battery go completely dead when in use, the computer shut down of course. When charged and turned on, again failed to boot up and displayed the folder with the question mark. In addition it also when booting up makes a mechanical sound like gears turning??
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
選択されたソリューション
Will need some more information, what model of mac is it? Grinding noise is usually a fan or hard drive problem. Some of the newer unibody laptops had a problem with the hard drive cable being faulty and would have strange errors.
このアンサーは役に立ちましたか?
スコア 0
コメント:
Ok figured out the sound is unrelated it is the cd drive. It is a macbook. I'm going to disassemble and reassemble again and see if it will boot up again.
さんによる
Ok, I opened up case disconnected - removed hard drive and reinstalled hard drive. Buttoned back up and it booted right up.??? Working fine.
さんによる
コメントを追加
回答を追加する
rhonda さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,106
