メインコンテンツにスキップ
発売日は2014年9月4日、モデル番号はSM-N915A
4回答 すべてを表示
Phone won't turn back on
So here's what happened; My phone started dying quickly and then started turning off and back on all by itself until it suddenly turned off and now won't turn back on at all. I ordered a replacement battery and the phone still refuses to turn on or do anything at all. What might be the problem? Any advice on how to fix this? Oh also the screen is cracked in one spot but I've never had any problems with the screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
do you know the model of phone you have?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Model # SM-N915R4
さんによる
コメントを追加
I have this problem also, ever since the June security update. The local Samsung Experience Center was unable to fix and suggested sending to the repair center. I decided to pass on this suggestion.
HOWEVER, this is a fairly common problem as documented on the internet (with no solutions as yet). You should be able to restart the device by removing the battery for 10 minutes and then reinstalling and starting. The problem will probably reoccur when you turn off or restart the device. There's an app called WakeLock that keeps the CPU running and prevents the freeze - but does drain the battery faster.
Good luck.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I’m having the same issue to add to that my battery gets hot when charging. This also the message I am getting when powered up.
Recovering booting…..
Recovery is not se android enforcing
Set warranty bit: recovery
It stays like this and nothing else happens.
さんによる
コメントを追加
回答を追加する
Nina Borseth さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 6
今までの合計 2,189
