Pc beeps fan turns but won't turn on
I recently cleaned my pc after which when I try to turn it on it won't.
It deeps once and cpu fans turn on for a second but that's it.
Does not even go to boot screen.
I tried turning it on with just the essentials but still same thing happens.
I did a bios reset but still same result.
Pretty sure all the cables are in the correct place and psu is good.
How did you clean the PC? Using a can of air is best and use vacuum cleaner edge tool to clean dust from the chassis but not the system board. Never use damp cloth on the electronics.
DrGlowire さんによる
Did you remove any components?
Reed Crosby さんによる
