メインコンテンツにスキップ
Problems with motherboard and detection with PC Nexus 7 2012 16GB
Hello everybody,
I read a lot of from different sources and forums how to do "rise from dark", but these advices I know it and for my case not worked.
I bouth this tablet from since first day. I played games, watch films and everythings with tabled what it can normaly do - 5 hours per day sometimes less. Least 2 years (2015-2017) I use only little bit, because od version Andriond and I know battery hold for 3 hours max...
But half a year ago is dead completly. I think its againg problem with battery a take battery out and charge on inteligent charger without any problems. Put it back and not work.
So I start think what happend. I used also conneted with PC but device was not recognized.
And here is problem:
- Dont want turn on every possible combination with full charged battery.
- Dont want recognized with three different PCs with Win7 and Win10.
- No sound, no heat, no flashing I think also no charging. I used fortests Voice meter and Fluke IR camera not cheap devices.
I have really bad feeling about mainboard is damaged but how is this possible? I used tablet only at home and never dorp down to floor and nothing is break.
What do you think? or what I can try to be sure what is broken?
Big thanks for any advices
Noro
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Try not to use it too much as it could overheat. Also you may have 'overcharged' it. What this means is the device was already 100% and you put it on the charger. This can lead to less battery life.
Would recommending to turn the pc off (If it already is), and pull the power plug and keep it like that for maybe 1 to 2 hours (Maybe less).
I would highly recommend bringing it to the shop you have brought it from and they can tell you what the problem may be or they can tell you where to bring it to get it repaired.
Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Norbert “Bujak” Mestanek さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 81
